how to resolve " your build of window will expire soon"
2024-09-09T14:00:10+00:00
I have using window 11 home, and I enrolled in window insider preview though beta channel.
my window is activated with a digital license linked to my Microsoft account.
when I switched on laptop (realme book slim) , a window popped up showing message " your build of window will expire on 15 September 2024. you should move to new build as soon as possible".
in window updates section, its showing "you are up to date" that means there is no update available to install.
because I'm not able to upload the images here, I share google drive folder link in which all the images available
(https://drive.google.com/drive/folders/1xBeohp8mbFhRm-XTkJ1cDvhYrA-5MhYW?usp=drive_link)
what should I do to resolve this issue in authentic way asapm
Pauli O 16,380 Reputation points Volunteer Moderator
2024-09-11T19:06:35+00:00
Since you have build 26100.1742 you can leave Insier program by deleting WindowsSelfHost key from registry.
This will lave you rather stable preview of Windows 11 v24H2 which is be released to public later this year, but it will get monthly cumulative updates on patch Tuesdays (Second Tuesday of month).
  1. Open open regedit (push Win key and type regedit).
  2. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsSelfHost
  3. On left panel right click that key and delete it.
  4. Close regedit and restart.
  5. Check your insider settings to see that its out of Insider Program.
  6. Check for updates to get latest C.U.
Edit 30/July/2026
If you are having this issue in 2026, refer to these articles:
https://yourwindowsguide.com/2026/07/this-build-of-windows-will-expire-soon.html
https://learn.microsoft.com/en-us/answers/questions/5940858/windows-insider-preview-certificate-renewal-expira
No. There is no action needed on your side to resolve the “Your Windows Build will expire soon message”this Build of Windows will expire soon” message, since for most of the channels, the Build with updated expiry date isn’t released by Microsoft.
23 additional answers
  1. Pauli O 16,380 Reputation points Volunteer Moderator
    2024-09-10T17:53:35+00:00
    Follow my another option to do in-place repair.
    Is your device fully compatible to run Windows 11?
  2. Johnny55 5,155 Reputation points Volunteer Moderator
    2024-09-10T18:39:29+00:00
    Hello ashokm99,
    You are actually running an old Dev Channel build 23545.1000 that was released over a year ago on Sept. 13, 2023. Why have you waited so long to update.
    Please follow Pauli's advice above and download the ISO image of 26100.1150. Mount the image file within windows and run setup.exe. This is what is known as a repair install. This will become this Fall's Release build.
    Suggest deleting the entire WindowsSelfHost Key to take you out of Insider. It will be rebuilt after a reboot:
    Regards,
    2024-09-10T18:45:39+00:00
    yes it supports W11.
    i download (release Preview channel ISO 26100.1150)
    ![](https://learn-attachment.microsoft.com/api/attachments/7ce390d4-66fa-41c0-9111-829cfb739659?platform=QnA
    i don't understand how to do further steps
    can you please explain this in details ?
  4. Pauli O 16,380 Reputation points Volunteer Moderator
    2024-09-10T18:56:52+00:00
    Open File explorer
    Located downloaded ISO,
    Mount it (double click or right click and select mount).
    This will open ISO to new virtual disk.
    On that disk run setup.exe to start in-palce update.
