Build 23493 is out to Dev Channel Insiders
CrazyKats 19,680 Reputation points Volunteer Moderator
2023-06-29T17:00:31+00:00
Live in W.U.
    2023-07-01T17:55:05+00:00
    Yes you are correct I am still missing RunAsPPLBoot. 🤷‍♂️
    I was attempting to wait for MS to apply their correction, rather than use one of yours (ours), but it has been a long wait and I am vacillating on which way to go. It's 5 months now since it started and MS appear very uninterested. After telling us it is important not to use any other workaround as they are working on a fix?
    Davy.
    2023-07-01T18:10:18+00:00
    Davy.
    I have never seen so much inconsistency as with the Security updates.
    They never have any explanation about what the changes are doing, and every time they release a new KB5007651 there is a new screwup. 😜🤷‍♂️
    This is the latest (2306) I got on one system and still does not work correctly. 🤐
    2023-07-01T22:22:37+00:00
    Sometime yesterday evening or today, my new Settings with Home page + shortcuts has disappeared.
    Just got the old Settings page again.
    Short time short cuts...?
    Davy.
    https://aka.ms/AAldtxf
  4. Paul Chou 1,471 Reputation points
    2023-07-01T23:43:26+00:00
    here are my screenshoots. before and after. Before is left and after is right. ImageImage
    2023-07-02T00:14:37+00:00
    Did you try deleting the IconCache.db?
    That seems to be a common suggestion for the problem of blank desktop icons.
    C:\Users*Username*AppData\Local
    **** Fix White Blank Icons on Desktop in Windows 11/10 (thewindowsclub.com)
    How to Fix Blank Icons in Windows 11 – TechCult
