but everytime after restart the audio driver resets
Low volume output on windows 11 21H2 when compared to windows 10 21H1
I have an issue where the volume for my pc is very low, for system and third party applications. I have ensured all volume settings are on max
The volume is appx 50% compared to normal, any advice?
Thank you
Windows Insider program | Windows Insider preview | Devices and drivers
2022-07-12T13:03:10+00:00 -
2022-08-11T02:04:56+00:00 same issue here plus the low volume.. Windows 11 is trash..
2022-08-11T13:50:19+00:00 This solves the problem, it is not Windows 11 but the whole Audio engine
Just try this and see
Change the Registry from whatever it is to the other
Open on the RUN command "regedit" (no quotes)
Navigate to the path:
Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Bluetooth\Audio\AVRCP\CT
if it is set to 1, change it to 0
and if it is 0 change it to 1
REBOOT
Bingo
2022-08-26T20:10:28+00:00 Latest update fixed it for me (KB5016691).
2022-08-27T13:14:39+00:00 Same issue. Volume bar under output settings barely goes above 50%
Nothing in thread has fixed issue.
