I have the same issue on my Lenovo Think Pad after installing Windows 11
Low volume output on windows 11 21H2 when compared to windows 10 21H1
I have an issue where the volume for my pc is very low, for system and third party applications. I have ensured all volume settings are on max
The volume is appx 50% compared to normal, any advice?
Thank you
Windows Insider program | Windows Insider preview | Devices and drivers
2022-02-26T03:33:25+00:00 -
2022-03-15T10:31:09+00:00 same here HP omen, sound start good and go down slowly to be very low :(
2022-03-15T15:24:08+00:00 My speakers sound fine if I run a test through settings. It comes out loud.
But when I try to get any volume through an app or program, even at 100% the sound is low.
2022-05-28T04:49:59+00:00 Im having the exact same problems! Let me know if you figure this out.
CrazyKats 19,760 Reputation points Volunteer Moderator2022-05-28T13:15:03+00:00 You are replying to a post that is almost a year old.
If you are having audio issues please open your own
thread and give details of your issue.
Also include PC, build #, etc.
