Low volume output on windows 11 21H2 when compared to windows 10 21H1
2021-07-18T11:23:06+00:00
I have an issue where the volume for my pc is very low, for system and third party applications. I have ensured all volume settings are on max
The volume is appx 50% compared to normal, any advice?
Thank you
Windows Insider program | Windows Insider preview | Devices and drivers
    2021-07-22T12:32:27+00:00
    Thank you
    I had the same problem but noticed with the use of my Airpods.
    For me, it worked as follows:
    1- Uninstall all sound drivers for that device in device manager.
    2- Then uninstall all bluetooh sound drivers for that device as well.
    3- Remove the device and then restart the computer.
    4- Connect/Add your device again.
    It worked for me.
    Tive o mesmo problema, mas notei com o uso dos meus Airpods.
    Para mim, funcionou da seguinte forma:
    1- Desinstale todos os drivers de som para esse dispositivo no gerenciador de dispositivos.
    2- Em seguida, desinstalar todos os drivers de som bluetooh para esse dispositivo também.
    3- Remova o dispositivo e reinicie o computador.
    4- Conecte/Adicione seu dispositivo novamente.
    Funcionou comigo.
    2021-07-18T11:43:36+00:00
    welcome to the club. check the feedback hub, tons of reports about the same issue
