Build 19042.906 and 19043.906 are available in RPC and Beta Channel
Pauli O 16,380 Reputation points Volunteer Moderator
2021-03-25T17:29:21+00:00
New CU's are available together with new Feature Experience Pack.
Releasing Windows 10 Build 19042.906 (20H2) to Release Preview Channel | Windows Insider Blog
  1. Johnny55 5,155 Reputation points Volunteer Moderator
    2021-03-25T20:28:36+00:00
    Hi Suat,
    Does this look familiar:
    Clean Installed 19043 in the RP vm. I removed the Enablement kb5000736 to use WU for RP. Not a chance. Putting this one back to snapshot of 19043.
    @Eddie, would you explain why on Insider Download Page, 19043.867 ISO is available for RP while Beta still has older ISO of 19043.844.  More MS secrecy  ;-)
    Regards,
    Edit: Would MS kindly start including extension numbers for ISO downloads for Insider and MCT. We would know if image has been updated at a glance. Appreciated if someone from MS listens.
    2021-03-25T20:40:39+00:00
    What SKU of Windows are you running? Have you made modifications to enable or disable features?
    2021-03-25T20:57:30+00:00
    Hi Suat,
    Regards,
    There's no secrecy, just a mismatch. Already pinged some folks to look into it. I'll also pass along the feedback on the extensions, but I wouldn't expect them to always match what the most recent is from WU.
    -Eddie
  4. Johnny55 5,155 Reputation points Volunteer Moderator
    2021-03-25T21:14:57+00:00
    -Eddie
    Thanks Eddie. I wouldn't expect the ISO images to match recent WU. By displaying ext. one would spot an image upgrade at a glance. Same with downloading MCT for Release versions.
    Regarding Suat's issue, I had clean installed a custom ISO of 19043.899 and that failed with Dism as well as WU. There should not be such a thing as mismatch in these cases. Different Error code:
    Oh well, back to the drawing board on this vm. Have a great weekend Eddie, and a few cold ones around the fire. Cheers!
    2021-03-25T21:41:50+00:00
    Sorry for late reply. My PC was busy trying things to install KB patch.
    First I integrated KB5000842 into the ISO ( build 19043.844 ) which I had downloaded from MS website several days ago. This must have brought my ISO to build 19043.906.
    I installed this build over my build 19043.899, thinking that I would reach build 19043.906.
    But to my surprise, I saw that my PC ended up in build 19043.867 instead of build 19043.906. It downgraded. EDIT: This statement is incorrect because I inadvertently integrated patch KB5000842 into a different index number in the ISO. Not into my edition of Windows 10.
    Then I installed KB5000842 over build 19043.867. Now I have build 19043.906.
    Now I have achieved my goal, somewhat indirectly, though.
    I have Windows 10 Pro. If this is what you meant by SKU.
