Hello Eddie.
In Spain it also cannot be installed
Best regards.
New CU's are available together with new Feature Experience Pack.
Releasing Windows 10 Build 19042.906 (20H2) to Release Preview Channel | Windows Insider Blog
Hello Eddie.
Best regards.
That error generally occurs when you make unsupported modifications to the system.
-Eddie
Thanks for your response.
By the same method, I could install the KB patch that brought my build to 19043.899 but I could not install the KB patch that would bring my build to 19043.906.
Moreover, the two patches have the same KB number.
Therefore, I don't understand what kind of unsupported modification I could have made to my PC between the two KB patches.
Could you please elaborate ?
Regards.
-Eddie
