RS-Prerelease Build 21337 is out to Dev Channel + KB5001618 to .1010
2021-03-17T17:00:40+00:00
Live in W.U.
    2021-03-23T18:33:28+00:00
    Thanks for this clarification, Eddie.  And I am glad, it's nice, I saw this (just) before adding an Upvote on a non-existent 'bug' 😉
    Great webcast, today, btw.  Thanks.
    Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/7a7675c7-bc31-44db-a38b-a27880bcccda?platform=QnA
    2021-03-23T19:00:33+00:00
    well I can report that this version didn't work either, and for the same nvme reason, I believe. as it came up with this       " WHEA_UNCORRECTABLE_ERROR bugchecks...
    KM
    This is still listed in our known issues list on the blog post: aka.ms/wip21337. It's also noted that the CU makes no changes. We are working on a fix for this, that should be available soon. Appreciate your patience.
    -Eddie
    Nvme issues there are in new builds in this week ? (Eddie) because I got WHEA_UNCORRECTABLE_ERROR with file unzipping ...
    2021-03-24T04:11:08+00:00
    I'm getting an attention page, but there is nothing that I can do. And the install is stuck at 35%
    2021-03-24T04:21:35+00:00
    To find the License type;
    * Please right click START the search and open CMD as ADMIN.
    * Type slmgr /dli and press enter and kindly upload a screenshot of the result here.
    2021-03-24T13:01:29+00:00
    The one thing on the left side that stands out to me is:
    Your organization has turned off automatic updates.
    Is this a work PC?
