RS-Prerelease Build 21337 is out to Dev Channel + KB5001618 to .1010
2021-03-17T17:00:40+00:00
Live in W.U.
    2021-03-22T15:00:02+00:00
    Please, great friend Eddie, ask the canary testers to test the restart process and also use a nvme ssd
    As I've stated before, we test restarts. We also still have NVMe issues listed in the known issues list.
    -Eddie
    2021-03-23T08:58:45+00:00
    Will News & Weather popout ever be appearing on taskbars other than at the bottom of the screen?
    Are you meaning if you move the Taskbar to the sides you have
    no News & Weather?
    I know that was happening when it first came out.
    If it's still happening file it in the Feedback and share the link
    here for Eddie (MSFT) to see.
    Correct - It's never worked for me on left of screen but, has if taskbar at the bottom
    https://aka.ms/AAbmrc4
    2021-03-23T11:42:59+00:00
    My experience with the nvme problem is that on 1 pc with a Samsung 500MB the problem did show up twice I think ?. The first time after the install, the pc crashed and a message stated that information was being taken and then the pc would be restarted. And this did happen. The second time it crashed , only a short time later, and the same message appeared and this time I actually read the message. And it was as I stated.  " WHEA_UNCORRECTABLE_ERROR bugchecks... and again it said that information was being taken. And then the  pc restarted. That problem has never happened again on that pc !! And that was more than 10 days ago. The second pc has 2 nvme cards, as I said. One is a Samsung 2TB , different from the other pc, and a Corsair 2TB.
    KM
    2021-03-23T13:00:34+00:00
    no News & Weather?
    Currently, it's a limitation in the app, not a bug.
    -Eddie
    2021-03-23T15:41:05+00:00
    no News & Weather?
    -Eddie
    Cheers for that
