Canary (.1000) downloaded and installed with no issues.
Build 26052 is out to Canary & Dev Channel
Deleted
2024-02-08T22:46:15+00:00 -
Deleted
2024-02-09T01:24:19+00:00 Thanks CK. 20% installing. Call me late to the party, I've been busy with other things including my wife's changing the network input, then calling me to fix the "no signal" message! Don't tell her I told you though! 😂
2024-02-09T02:10:36+00:00 Up and running with 26052, no problems so far.
I've read the release notes, and I have to say I sure don't understand how SUDO is going to help me! I listened to the tutorial, and I think it's supposed to somehow keep you from having to reboot after installing programs I never heard of. I guess I must not need it in spite of MS' apparent enthusiasm over it. 🤷♂️
