For those interested in what Sudo is about.
Build 26052 is out to Canary & Dev Channel
Drew - 810 Reputation points
2024-02-12T22:20:47+00:00 Please, no offence...
But this๐ link will work, to be notified ๐
CrazyKats 19,680 Reputation points Volunteer Moderator2024-02-12T22:36:55+00:00 Please, no offence...
Yes, as long as you click the Notify Me.
2024-02-13T07:12:34+00:00 I've had my first failure with Canary,
On an Asus TUF gaming board, 26052 locked up six times at the TUF splash screen, necessitating force stopping and restarting the machine. The first two times it was able to pick up the installation, and just restarted. The third time, however, it went right back to downloading again. but again locked up at the TUF screen. It then locked up a further three times, and when it finally reverted to 26040 again, I decided to give up until the next release.
I did think about trying an iso file from a well-known third party but got this response:
No downloads available
This build has known issues preventing the creation of a working ISO.
2024-02-13T07:42:43+00:00 No downloads available
Where did you read that?
I had no problems downloading and making ISO files for 26052.1000 and 26052.1100.
Used both ISO files for updates from 26040 and 23620 and also for clean install.
I don't have an Asus machine and I cannot comment on your specific problems. ๐คทโโ๏ธ
Some machines with Intel Arc Display Graphics had a problem with Display Audio that lost sound and could not be unmuted.
