RS-Prerelease build 25276 + ISO is out to Dev Channel
CrazyKats 19,595 Reputation points Volunteer Moderator
2023-01-12T18:00:13+00:00
Live in W.U.
Windows Insider program | Windows Insider preview | Other
    2023-01-16T20:57:50+00:00
    Well there you go! Just when I thought that my 25276 was getting boring. Ha!
    Davy.
    2023-01-17T13:49:52+00:00
    Finally got time to turn off One Drive @ start up; and as you say SharePoint immediately fails.
    So OneDrive aka SharePoint is mucking things up again.
    Edit. 17/03/23
    Started R.P.22621.1105 - SharePoint failed with this build when OneDrive is set to start at Start-Up.
    Started Beta 22623.1095 - SharePoint failed with this build when OneDrive is set to Start at Start-Up.
    Started P.B. 22621.1105 - No SharePoint fails - even if OneDrive is set to Start at Start-Up.
    Store does not show any OneDrive updates on any of my builds but Installed apps shows 12/01/23
    Davy.
    2023-01-17T17:28:50+00:00
    Edit. 17/03/23
    Davy.
    That is weird. I see the error also on public Build.
    I did not get the SharePoint error after I turned off OneDrive on 27256. You can see the version update in Installed apps.
    I never got the error with Public Build, R.P. or Beta because I never had OneDrive enabled to start. I saw that there was an update
    on OneDrive on all Builds, but I never even set it up. So, it was still disabled on startup.
    22621.1105, Public Build:
    These also happened on Public Build when I setup and started OneDrive. 🤷‍♂️
    After I disabled OneDrive, I did not see the error again on any subsequent system restart. 🤷‍♂️
    Beta 22623.1095 and R.P.22621.1192:
    As soon as I set up OneDrive on 22621.1105 I got the error, so I turned it off again on the new OneDrive settings which was only available after I completed the setup. 🤣.
    Got a second error when I started OneDrive again.
    I don't get the error if I leave it off.
    This link shows the different OneDrive settings menu, before and after the recent updates.
    Turn On or Off OneDrive Run at Startup in Windows 11 Tutorial | Windows 11 Forum (elevenforum.com)
    2023-01-18T01:42:09+00:00
    Hi Davy,
    I think I figured out why one of my machines gets the error even with Public Build 22621.1105.
    Two machines with Public Build 22621.1105 have different Version/Build of OneDrive. 🤷‍♂️
    The one that causes the error with SharPoint is the Preview Build 23.002.0102.0001
    This other one is not a preview, Build/Version 22.253.1204.0001 is not getting the error.
    Hard to say how the Preview version ended up on my public Build machine given that I never turned on this option below which would allow a Preview version of OneDrive. 😎🤷‍♂️
    Note that this same option is on by default on Windows insider and cannot be changed. (Grayed out).
    Edit:
    I restored my backup of the public Build 22621.1105, and it showed this version from Jan 13. As soon as I started one drive it updated again to 23.002.0102.001 which is the one that causes the error with Microsoft SharePoint. I just don't understand why different from the other machine with the same Windows Public Build. 😎🤷‍♂️
    After the restore it had this one:
    It was updated to this as soon as I started OneDrive:
    Added comment and screen shots to your FBH report, perhaps the moderator can split this discussion on a separate thread for OneDrive.
    https://aka.ms/AAj8ve3
    2023-01-18T05:48:33+00:00
    MS Store update:
