bf 2042 not launching on this build? anyone? help please
What is bf 2042?
What is bf 2042?
its a game called battlefield 2042
That is not a Microsoft game, so you would
have to contact the game support. I believe it's
an EA game.
Except, I will suggest it is the same as expecting support from Microsoft on a beta build OS; it is not available. By the same token a 3rd Party is unlike to offer support for anything being run on a beta OS.
Cheers,
Drew![](https://learn-attachment.microsoft.com/api/attachments/12a64a9b-e1aa-4484-accd-f6ad9fd2bffa?platform=QnA
So.. Finally the update worked after several turns.. But the update caused my internet to freeze my whole computer: when I open Edge or Chrome it freezes my pc after a moment and then I have to restart the computer manually.. Unfortunately I had to go back to the previous build.. if you’re reading this update 25276 might be the cause of the technical issues you also experience.. might have to wait for the next update after the 25276 build…
