RS-Prerelease build 21343 is out to Dev Channel
CrazyKats 19,585 Reputation points Volunteer Moderator
2021-03-24T17:00:21+00:00
Live in W.U.
  1. CrazyKats 19,585 Reputation points Volunteer Moderator
    2021-03-28T22:37:49+00:00
    Go to Settings, Update & Security, Recovery
    and Rollback to the last build if you haven't
    removed the Windows.old folder.
    If you wish to leave Insider totally you must
    use the Media Creation Tool and do a clean install.
    2021-03-28T23:36:14+00:00
    Heh really. you writting me as im dumber.
    i know what to do..
    but in fact god bless windows7
  3. CrazyKats 19,585 Reputation points Volunteer Moderator
    2021-03-28T23:47:10+00:00
    ==partial quote==
    **** it. i must leave insider. my device is longer not working as working
    Your comment, I was just answering it. No one called you dumb.
  4. Drew - 810 Reputation points
    2021-03-28T23:55:47+00:00
    God bless Windows 10 (not meaning Insider Builds)
    As 'CK' has said, to leave WIP, one has to clean install Windows 10.
    **Windows 7 is not supported & should not be connected to the Net.**Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/d68b7912-4e9c-404b-b454-ae72144e1c3b?platform=QnA
  5. Deleted
