Build 23403.1001 is out to Dev Channel Insiders
CrazyKats 19,675 Reputation points Volunteer Moderator
2023-03-08T18:01:27+00:00
Live in W.U.
    2023-03-08T20:09:40+00:00
    Hi Sibro,
    Weather info is showing up fine in Lock screen with this Build 23403.1001. 😉
    2023-03-08T20:29:53+00:00
    Hi Sibro,
    Hi fg,
    Good to know. Unfortunately, I had to abort the upgrade because got stuck at 58% and the CPU was at a constant 100% getting hot. 😒
    I'll download the ISO and try an in-place update later.
    2023-03-08T22:07:33+00:00
    Seems I still have my old problem with Store apps.
    Store says 5 apps "modified"?
    Reliability Monitor shows 1 (different) app installed?
    Davy. https://aka.ms/AAjx6nm
    2023-03-08T22:31:56+00:00
    Privacy & Security - Windows Security - Open Windows Security & all other links do not work.
    Davy.
    https://aka.ms/AAjwd7t
    2023-03-08T23:16:56+00:00
    Davy.
    Weird, there was an old issue like that, but I don't remember which Build.
    Works fine here on this system with 23403.1001, all the links on the left open fine. 🤷‍♂️ I'll check another machine when it is done updating.
    SecurityHealth is empty in this case.
    Edition Windows 11 Pro Insider Preview
    Version 22H2
    Installed on ‎3/‎8/‎2023
    OS build 23403.1001
    Experience Windows Feature Experience Pack 1000.22647.1000.0
