Build 23403.1001 is out to Dev Channel Insiders
CrazyKats 19,675 Reputation points Volunteer Moderator
2023-03-08T18:01:27+00:00
Live in W.U.
    2023-03-17T19:19:15+00:00
    After coming to this build from 22H2, I looked in the Store to see what had been updated and found numerous things had been. So I checked for updates to see if there was anything else, and one more thing tried to install/update:
    Web Media Extensions
    But it doesn't, just saying "Something happened on our end," even if you Retry. If you click into it, it mentions Code: 0x80070057.
    I see a few mentions of this in Feedback, as it appears in various builds from time to time, but it's new to me.
    Had the same error yesterday, but today it updated fine. 🤷‍♂️
    Perhaps you have to wait and then try again later.
  2. Deleted
  3. Deleted
  4. Deleted
    2023-03-22T05:06:48+00:00
    Interesting to see that on this Build 23403 and also on Canary 25314 they may have fixed a problem that was reported years ago and never fixed till now.
    Finally, the window showing the progress of the System image backup opens and stays in the foreground instead of hiding behind the other open windows.
    Not sure if it was fixed by coincidence or intentionally, but it was a pleasant surprise.
    Better late than never, I hope they don't break it again. 😉
