I'm not seeing either of the problems that you and fg2001 refer to.
Ni-Release Build 22581.200 KB5013296 is out to Dev and Beta Channel READ THE BLOG
CrazyKats
19,680
Reputation points
Volunteer Moderator
2022-03-29T13:56:43+00:00 -
2022-03-29T14:33:23+00:00 I'm not seeing either of the problems that you and fg2001 refer to.
As it happens, neither do I John.
Davy.
2022-03-29T20:32:55+00:00 -
2022-03-30T04:11:12+00:00 Newest build installed fine on both laptops.
