I installed the latest release (Ni-Release Build 22581.100 KB5013283 ) which impacted my wireless adapter driver. My system did not recognize the driver so I rolled my system back to the previous version and all is well.
Ni-Release Build 22581.200 KB5013296 is out to Dev and Beta Channel READ THE BLOG
CrazyKats
19,680
Reputation points
Volunteer Moderator
2022-03-26T13:00:54+00:00 -
2022-03-27T00:38:09+00:00 -
2022-03-29T13:23:29+00:00 This build has broken powershell (freezes over and over), and makes the search feature in the start menu hang as well.
2022-03-29T13:34:54+00:00 This build has broken powershell (freezes over and over), and makes the search feature in the start menu hang as well.
If you click Windows Update > Update History > Uninstall Updates select KB5013283 you can remove the update.
Davy.
