Hi Sibro,
I finally think I isolated the experimental feature that was causing the 0xc0000005 when booting in Safe mode.
Today MS disabled 4 different features and enabled a new one, and the problem was no longer occurring.
So, I just reenabled those one at the time and found the culprit. 😎
It is listed as:
AugmentedEntryPointBadging: 36718398
I have no idea about what it is or does, but without it the bug is gone. 🤣🤣🤣🤣
I reproduced the same 0xc0000005 error by enabling the same above feature on two other boxes that never failed before. 🤐
The other 3 features have something to do with Widgets behavior and the changes that we have seen recently.
The added one they enabled is listed as:
LiteWhiteNTH: 33355279
Whatever that does? 🤣
Thanks MS, for not explaining anything they do under the covers. 🤐🤐🤐🤐🤐
https://aka.ms/AAhgxeo
