RS-Prerelease Build 25158 + ISO is out to Dev Channel
2022-07-13T17:00:12+00:00
Live in W.U.
Windows Insider program | Windows Insider preview | Windows AI
  1. CrazyKats 19,760 Reputation points Volunteer Moderator
    2022-07-19T15:39:19+00:00
    I ignore it because I know the update has
    installed and it happens so randomly that
    it can't even be reproduced.
    2022-07-19T15:53:39+00:00
    It may be part of more issues which do not show up every time.
    You haven't seen the other one that I've now seen a few times with this Build.
    I'll file an FBH report anyway. If we ignore bugs, they will never get fixed. 😉
    https://aka.ms/AAhi7n8
    And again:
    Looking at security about, it shows it is already installed. 🤣
    Yet, I hit retry on W.U. and it completed the installation again without problem. 😜😜😜
    and after that it gets worse, like in a loop with the same update. 🤣🤣🤣🤣
    Ran troubleshooter, but that did not fix the problem, still looping on the same install. 😎
    Added recording to FBH report
