Hi, and using diskpart? This is what I used, (dual boot win11/server) from the recovery command prompt,
I did that because I have multiple volumes, plus the ones from Dell. So I assigned letters from there.
I did not disable secure boot...
After updating to Build 27764 in the Canary Channel, some Windows Insiders are reporting hitting the issue that previously impacted the Dev Channel where an “Your organization used App Control for Business to block this app” dialog is shown when attempting to use or install certain third-party apps on your PC due to an incorrect policy being enforced. The following steps should mitigate the issue:
If you are dual-booting between the Canary Channel and the Dev Channel or another version of Windows, you will need to do this workaround BEFORE booting to the other OS.
If the above steps do not work, you may need to disable Secure Boot first and follow these steps:
In small cases, your PC may not boot into Windows. To get out of this state, you can follow these steps:
Excelente. funciona perfecto. Gracias.
On ending entering script get totally errored result starting with " Cannot find drive. A drive with the name 'mountvol s' does not exist" Please help!
Please read the instructions on 1st post step by step. The drive will have a letter S: after you issue the command "mountvol s: /s". 😎🤷♂️
