Build 25267.1000 is live in Dev, ISO out
2022-12-14T18:05:26+00:00
    2022-12-26T15:27:18+00:00
    The second Insider PC is still giving me problems. Tried to install about six times already. Using WU and ISO, all stopped at the same point. No results using scans and Dism.
    Goes to 30% after the initial reboot, the restarts. The screen goes blank for a few minutes at 48%. Eventually goes to 64%, where it stays. Have left it for a couple of hours, before eventually pressing the reset. It does go back to previous, with a message after log-in:
    MB GIGABYTE Z590 AORUS ELITE AX
    Processor 11th Gen Intel(R) Core(TM) i9-11900 @ 2.50GHz 2.50 GHz
    Installed RAM 128 GB (128 GB usable)
    System type 64-bit operating system, x64-based processor
    GPU GIGABYTE GTX 1060 G1 Gaming Rev 2.0 (GV-N1060G1 GAMING-6GD)
    Samsung SSD 850 PRO 1TB
    Plus a few other SSD's
    2022-12-26T15:41:22+00:00
    I have had similar errors with builds. Mostly they point to drivers.
    Have you tried running SetupDiag
    https://learn.microsoft.com/en-us/windows/deployment/upgrade/setupdiag
    To see if it identifies the particular driver.
    Davy.
    2022-12-26T16:27:18+00:00
    Davy.
    Thank you very much Davy.
    hadn't run it, which I did immediately. Picked up a driver, which appears to be Microsoft printer driver
    <DriverPackages>
    	&lt;DriverPackage Inf="oem39.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem56.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem50.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem38.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem37.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem65.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem63.inf" BlockMigration="True" HasSignedBinaries="False"/&gt;
    	&lt;DriverPackage Inf="oem15.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem9.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem5.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem35.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem24.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem2.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    	&lt;DriverPackage Inf="oem46.inf" BlockMigration="False" HasSignedBinaries="True"/&gt;
    &lt;/DriverPackages&gt;
    Published Name: oem63.inf
    Original Name: prnms009.inf
    Provider Name: Microsoft
    Class Name: Printer
    Class GUID: {4d36e979-e325-11ce-bfc1-08002be10318}
    Class Version: 4.0
    Driver Version: 06/21/2006 10.0.25252.1000
    Signer Name: Microsoft Windows
    Wonder if this is it. Have heard about this driver a while ago (I think). Don't really know as to what to do next
    2022-12-26T16:36:58+00:00
    Are you OK with uninstalling the printer?
    Then re-attempting the update?
    You can always reinstall after completion.
    Davy.
    2022-12-26T16:46:51+00:00
    Actually not, because I don't know where and which to uninstall, or delete
