RS-Prerelease build 25309 out to Dev Channel
CrazyKats 19,425 Reputation points Volunteer Moderator
2023-03-02T18:00:24+00:00
Live in W.U.
Windows Insider program | Windows Insider preview | Other
    2023-03-02T19:15:46+00:00
    Guessing this might be going forward, trying to get clarification,
    because mine were moved and enlarged again.
    Otherwise both PC's up and running.
    They sure did not fix this.
    With this Build like the previous Build they screwed up the desktop layout and the size of the desktop Icons. Pretty annoying. Are they reading the FBH reports?
    https://aka.ms/AAjtnqf
    https://aka.ms/AAjnkut
    All my icons changed from small to medium and rearranged the whole desktop.
    Same happened to Control panel, reverted back to default.
    2023-03-02T19:17:32+00:00
    Of course we get
    But 2023-02? surely 2023-03?
    Davy
    2023-03-02T19:21:50+00:00
    If you post CK, put the link here please and I'll update etc.
    Davy,
    2023-03-02T20:04:26+00:00
    Thanks Davy. Software Distribution folder emptied & update restarted. I knew that 2nd restart wasn't likely to succeed - I think it was Einstein who said it was lunacy to do the same thing over again expecting different results. Yep, he sure was right! 😊
    2023-03-02T20:22:58+00:00
    Thanks CK. Dell Insider laptop now on 25309. No install issues. I keep no icons or shortcuts on the desktop as I keep what I use on the taskbar.
