RS-Prerelease build 25309 out to Dev Channel
CrazyKats 19,425 Reputation points Volunteer Moderator
2023-03-02T18:00:24+00:00
Live in W.U.
Windows Insider program | Windows Insider preview | Other
    2023-03-02T18:36:52+00:00
    Restart
    25309.1000
    Davy.
    2023-03-02T18:45:55+00:00
    Up at 18.45
    Davy
    2023-03-02T18:50:14+00:00
    Error installing after rebooting. I just restarted it without writing down the hex code, sorry. It took 6 min. to download, and the first reboot was after 28 min. I did check to make sure there was enough free space on the C: drive. If it fails again, I'll go delete the update files before retrying. This is the first time I've run into this in a long time.
  4. CrazyKats 19,425 Reputation points Volunteer Moderator
    2023-03-02T19:02:03+00:00
    Guessing this might be going forward, trying to get clarification,
    because mine were moved and enlarged again.
    Otherwise both PC's up and running.
    2023-03-02T19:05:55+00:00
    It has got to the stage HB that I ALWAYS either System - Storage - Clean; or empty the Software Distribution folder; EVERY time before updating.
    It may not be the best for troubleshooting purposes but it sure speeds up the update/install.
    Davy.
