RS-Prerelease Build 22478.1012 KB 5007328 is out to Dev Channel Updated
CrazyKats 19,415 Reputation points Volunteer Moderator
2021-10-14T17:00:10+00:00
Live in W.U.
The .1012 update is just a test of the servicing pipeline,
no fixes.
    2021-10-15T01:58:09+00:00
    Here is another bug:
    Trying to open command prompt or power shell or windows terminal as administrator takes forever (over 30 secs) before it pops up the message asking for permission to run.
    I don't see that here, in fact I don't see any of the bugs reported.
    Wonder if it has to do with Windows Update, I updated via ISO.
    Same bugs on 2 different machines, both W.U. from 22471 to 22478.
  2. CrazyKats 19,415 Reputation points Volunteer Moderator
    2021-10-15T01:59:16+00:00
    Saw this on Twitter, not sure if it will help.
    And the other reply was that it worked.
    2021-10-15T02:03:29+00:00
    here, take a look
    the delay is to click UAC not recorded for some reason🤷‍♂️
    2021-10-15T02:12:09+00:00
    Hi C.K.
    Signing out and back in seems to solve the problem temporarily, but fails again the same way after a restart.
    Nothing to do with Nvidia, one of the failing machines has AMD display adapter.
    Also I do not autologin.
    2021-10-15T02:21:17+00:00
    here, take a look
    Hi Sibro,
    Looks like signing out and back in fixes both issues for the Task Manager and the delay on the commands running as administrator, but only temporarily, the problems show up again exactly the same way after a restart.
    Updating a third machine now, we'll see if I get the same bugs.
