RS-Prerelease Build 22478.1012 KB 5007328 is out to Dev Channel Updated
CrazyKats 19,330 Reputation points Volunteer Moderator
2021-10-14T17:00:10+00:00
Live in W.U.
The .1012 update is just a test of the servicing pipeline,
no fixes.
    2021-10-18T22:21:22+00:00
    Rebooting does not reproduce the issue for me. Unfortunately, I'm at a spot where I can't do a roll back and test. We do have at least one other internal repro that we are working off of.
    -Eddie
    2021-10-18T22:30:49+00:00
    Not if you read his comments and how he reproduced it.
    It is really not unusual that bugs only show up for some users, as I said there are many variables that can cause the differences.
    Nothing new there.
    I read it, he updated and got the bug so what? same as everybody else who got it. It may come from the previous build for all we know or something in common to all of you.
    If you would have said that in your original comment (before the edit), I wouldn't have reacted so harshly.
    Anyway, we are cool. Cheers!
    2021-10-18T22:32:29+00:00
    When you open Task Manager and click on the Users tab, what do you see there?
    -Eddie
  4. CrazyKats 19,330 Reputation points Volunteer Moderator
    2021-10-18T22:41:23+00:00
    >"But the windows you show are not familiar to me."
    To get USB, local drives or some other host devices to be available in Hyper-V VM you have to enable Enhanced mode"
    In these instructions: Use local resources on Hyper-V virtual machine with VMConnect | Microsoft Docs
    • Setting in step 4 enable Enhanced mode and then you can turn it on by clicking Enhanced mode button.
    • Setting in step 6 make Enhanced mode as Default.
    Here is more info using Enhanced mode:
    Share devices with Windows virtual machines | Microsoft Docs
    This is a thread about the newest build, not about Enhanced
    mode in VM.
    Drew was advised that if the topic needed discussion to start
    a new thread. Please follow that advice.
    2021-10-18T22:48:55+00:00
    What method are you using to update the device to new builds?
    -Eddie
