RS-Prerelease Build 22478.1012 KB 5007328 is out to Dev Channel Updated
CrazyKats 19,415 Reputation points Volunteer Moderator
2021-10-14T17:00:10+00:00
Live in W.U.
The .1012 update is just a test of the servicing pipeline,
no fixes.
    2021-10-17T01:42:50+00:00
    This appears to be fixed now.
    2021-10-17T02:03:50+00:00
    OK.. I'll try the update later and let you know
    2021-10-17T04:21:24+00:00
    @RGBell,
    What appears to be fix ? Which bug are you referring to ?
    2021-10-17T05:06:16+00:00
    Well, can't Finish because Win11 is a vm, ergo no direct USB connectivity recognised to Win11.
    fyi: you can share pretty much any host resource, including USB drives.
    Read this article, and if you'd like to discuss it further, please open a new thread so we don't go OT 😁
    Share devices with your virtual machine
    2021-10-17T06:34:26+00:00
    There are too many glitches if Windows 11 form Insider. I am facing too much problems.
