Up and running.
RS_Prerelease Build 22509.1011 KB5008918 is out to Dev Channel Read the updated Blog
2021-12-01T20:04:30+00:00 -
2021-12-01T20:05:15+00:00 No issues installing. Only unexpected thing I see (and don't like). Running control panel> devices and printers no longer shows the icon list but instead shows the settings style list.
I saw that, not sure why they consider these changes as improvements. 😉
CrazyKats 19,680 Reputation points Volunteer Moderator2021-12-01T20:19:25+00:00 No issues installing. Only unexpected thing I see (and don't like). Running control panel> devices and printers no longer shows the icon list but instead shows the settings style list.
It's all part of moving things out of Control Panel
2021-12-01T20:35:18+00:00 This update was smooth on a newer HP laptop, under an hour.
I see comments on Control Panel, I like to check Task Scheduler often. I have placed an Icon on the lower Task bar which is handy.
sofspra
2021-12-01T22:47:40+00:00 No issues installing. Only unexpected thing I see (and don't like). Running control panel> devices and printers no longer shows the icon list but instead shows the settings style list.
Which unfortunately is never an improvement. 🤔
