Thanks, CK. installing now on Dell #2. Will start Dell #1 later.
RS_Prerelease Build 22509.1011 KB5008918 is out to Dev Channel Read the updated Blog
2021-12-01T18:26:42+00:00 -
2021-12-01T18:40:39+00:00 Up and running on 22509. No problems so far.
I have to comment that the last 36% of the install takes far longer than the first 64%. In Task Manager I see a lot of pauses where almost nothing goes on. That seems to mean to me that it's communicating with MS at various points, and we're just at the mercy of the local server and MS to give the go ahead.
CrazyKats 19,680 Reputation points Volunteer Moderator2021-12-01T18:46:46+00:00 Up and running on both PC's.
Pauli O 16,380 Reputation points Volunteer Moderator
2021-12-01T19:03:28+00:00 Not so slow here, all three devices completed update about 45 min.
