Build 26100.712 to RP
2024-05-22T18:19:06+00:00
    2024-05-25T00:39:53+00:00
    @Barb Bowman, @Johnny55,
    I just tried another test on this machine (Build 26100.712), as suggested by Kyle Pflug on your earlier post.
    On Edge Settings appearance I set it to Dark and then the local Copilot App opened also in Dark mode appearance.
    Looks like there is more than one way to obtain the same result. 😎😂🤷‍♂️
    It also works with System default, assuming that the system is set for Dark color. 👍
    Edit:
    Got this error again when changing the color appearance. This is for MS to figure out. 🤷‍♂️
    2024-05-25T02:20:30+00:00
    @Johnny55,
    Here is another case for you with 26120.712. 😂😂😉
    2024-05-25T19:36:05+00:00
    Hi Johnny,
    I found an easy way to get a newer version of the Copilot App. See my last post on this thread below.
    That version also has the menu for the color. 👍
    Why is my Windows 11 Copilot the preview version? - Microsoft Community
    In this case I have both the old Side Pane PRE and the new App. 😉
  4. Deleted
    2024-05-28T02:03:13+00:00
    Found a way to reproduce the error mentioned earlier.
    With Build 26100.712 a new task was added in Task Scheduler to run periodically. It produces the error every time it runs. Clearly, they have a bug in PcaSvc.dll which is missing an entry needed to run the Task PcaWallpaperAppDetect.
    All you need to do to reproduce the error message is Right Click on that Task > Run and you get the error message.
    Otherwise, the message will only show at the time that the task is scheduled to run. 😎
    Edit:
    Fails also on Canary Build 26217.5000 https://aka.ms/AAqkfie
