ola boa noite nao estou conseguindo mudar o meu canal ele esta no dev e queria colocar o beta agradeço a ajuda
FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
- If you have Bitlocker enabled, please suspend it.
- Click Start
- In the search box, type cmd
- In the lower right of the search results, under Command Prompt, click Run as Administrator
- On the UAC prompt, click OK
- At the elevated command prompt, type: bcdedit /set flightsigning on
- Press Enter
- At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
- Press Enter
- Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
2021-12-26T01:01:21+00:00 -
CrazyKats 19,420 Reputation points Volunteer Moderator2021-12-26T01:03:55+00:00 The only way to change from Dev channel to Beta is
to clean install.
2022-01-28T16:26:27+00:00 It works!
2022-01-29T18:59:31+00:00 Hi Eddie,
Maybe you can assist me as I can't find anyone at Microsoft who can. I have a machine sitting on Windows 10 Pro Dev channel and it is stuck on trying to update to Windows 11 builds - the computer can't run Windows 11 so the update process is in a loop. I am not receiving Windows 10 Pro builds anymore and Microsoft told me I would automatically be moved from the Dev channel to the preview channel (that didn't happen).
Here is the details of my build:
Edition Windows 10 Pro
Version Dev
Installed on 5/7/2021
OS build 21376.1
Experience Windows 10 Feature Experience Pack 321.11803.0.3
How do I change from Windows 10 Dev channel to the preview or beta channels to receive Windows 10 Pro updates?
Please let me know if you have an answer or can point me to someone who can assist.
Thanks in advance,
Dennis
CrazyKats 19,420 Reputation points Volunteer Moderator2022-01-29T19:37:07+00:00 The only way for you to get off the build you
are on is to Clean install. You are on a build that is expired.
Use the Media Creation Tool here to do a clean install.
Back up all your important files, etc. prior.
