Este o teorie si nu este sustenabilă! am încercat și nu funcționează!
FIX: Insiders not able to switch channels - **UPDATED 8/3/2021**
Hello Windows Insiders!
Windows 11 is now in the Beta Channel, and some of you are wanting to move over from the Dev Channel. We've been getting some reports that some of you are not seeing the options to change in Settings > Windows Update > Windows Insider Program. We have a fix that should get you back on track. Please note, this fix is for devices that are not showing the Choose your Insider Settings and Windows Insider account settings, as in the image below.
If you are seeing this, please follow the steps below to restore the missing options:
- If you have Bitlocker enabled, please suspend it.
- Click Start
- In the search box, type cmd
- In the lower right of the search results, under Command Prompt, click Run as Administrator
- On the UAC prompt, click OK
- At the elevated command prompt, type: bcdedit /set flightsigning on
- Press Enter
- At the elevated command prompt, type: bcdedit /set {bootmgr} flightsigning on
- Press Enter
- Reboot the device
You should now see the missing options:
If performing these steps to not resolve your issue, please file a new feedback item in Feedback Hub, so we can investigate.
Thank you!
-The Windows Insider Team
2021-08-24T15:48:13+00:00 -
2021-08-24T16:11:02+00:00 It's a theory and it's not sustainable! I tried and it does not work!
This is not a theory. This is the fix for a specific issue. What do you see in your Windows Insider Settings page?
-Eddie
2021-08-24T19:43:24+00:00 Can you forward a link to the minimum hardware specs? I'm running a 2.5yr old workstation-class notebook with Win Pro for Workstations. It's unlike MSFT to require 90% of the installed base to upgrade hardware for a new release. I know, I used to work there. If that's the plan Win 11 sales will lag behind those of Win 8 and Vista!
Specs, please!
Richard
2021-08-24T19:46:58+00:00 This means your device does not meet the minimum hardware requirements. You are in the red column in the chart here: https://aka.ms/FlightUpdates2021
-Eddie
So why did the Insider Program leave me installed in the Dev build cycle rather than just stating the facts as you've presented them?
CrazyKats 19,420 Reputation points Volunteer Moderator2021-08-24T20:09:22+00:00 This means your device does not meet the minimum hardware requirements. You are in the red column in the chart here: https://aka.ms/FlightUpdates2021
-Eddie
If you were already in the Insider Channel we were allowed
to move forward to Windows 11 for testing.
