Final Fantasy XIII input freezes on Save/Load menu with Windows 10 built Xbox Driver.
2015-09-18T08:59:03+00:00
Final Fantasy XIII and Final Fantasy XIII-2 is unplayable using built-in Windows 10 Xbox Drivers. Game stops receiving controller/keyboard input at Save/Load menu when using a Xbox Controller.
This has been an issue since the preview days of Windows 10.
It will work when switching to the downloadable Windows 7, 8 and 8.1 drivers but this breaks input in some WinRT games like Minecraft for Windows 10 and prevents accessing the Xbox DVR game bar.
I'm not an the only user who has this issue. It affects everyone playing these 2 Final Fantasy games on Windows 10 who plays with a Xbox 360 or Xbox One controller.
What can be done that doesn't involve playing around with drivers and breaking compatibility with certain games and Windows 10 features?
Windows Insider program | Windows Insider preview | Devices and drivers
2016-12-30T07:43:23+00:00
FIXED FOR ME
Nathan gave me an idea with his arbitrary fix by holding down the two triggers and moving the left control stick.
I've tried all the fixes in this thread, injectors, drivers etc, but Nathan's mention of the triggers led me to try to check my calibration on a whim.
What I noticed was that my Z-axis (triggers) was off center and recallibrated to ensure that all my axis reset to normal and sure enough, for whatever reason, the problem is resolved for me.
You guys may as well try it:
  1. Navigate to and select "Set up USB Game Controller" in Control Panel
  2. Ensure your XBox One controller is connected and select it
  3. Select Properties
  4. Under the Test tab, double check to ensure your Z axis is centered when at rest (it was skewed max for me despite functioning normally in games)
  5. Recalibrate as necessary until everything is calibrated as should be.
Try it out by launching FFXIII
Hope this helps you guys as it did for me!
Windows 10
Up to date controller drivers
Tested using both Bluetooth and USB connection.
2016-03-02T09:58:05+00:00
Just to let everyone know that the update is now live across Windows Update. Just tested with an Xbox One controller and everything works as it should.
2016-01-07T17:36:55+00:00
Ok I got this to reproduce using an Xbox one Controller. I've opened a bug and assigned to the correct team to investigate. Thanks for reporting this issue and being a Windows insider.
56 additional answers
    2016-04-18T19:36:14+00:00
    Sup dudes.
    Seems that the fix that they rolled in early March to the release channel has now been rolled back, seemingly because it was causing some unforeseen issues.
    So once more, bunch of games are broken again as of April 12th, KB3147458 is where the rollback happened.
    2016-04-19T08:09:55+00:00
    Here is how you can fix the Issue with FF 13 not working with Xbox one Controller. Worked for me and few others I know.
    To solve the issue:
    Go to device manager
    Select the Xbox Controller
    Right click and select "Update driver software"
    "Browse my computer for driver software"
    "Let me pick from a list of device drivers on my computer"
    And then select "Microsoft Xbox One Controller" instead of the previously installed "Xbox Controller"
    It all worked again after that.
    Could it be that they removed DirectInput support from new that driver?
