Build 25926 out to Canary Channel
CrazyKats 19,680 Reputation points Volunteer Moderator
2023-08-09T17:00:36+00:00
Live in W.U.
    2023-08-13T17:37:26+00:00
    Edit: Still have ongoing concern with Xbox Identity Provider. This is with the upgrade as well as the total clean install of this build.
    That is still happening on all my Canary machines.
    I read somewhere that it needs to be downloaded while signed in XBOX. I tried that, but did not make any difference, keeps giving the same message. The problem started with Build 25905, see FBH report below.
    https://aka.ms/AAlzfg7
  2. Johnny55 5,155 Reputation points Volunteer Moderator
    2023-08-13T19:02:24+00:00
    Thanks fg, upvoted and commented. This was the first time coming across this error.
    Regards,
    2023-08-14T17:01:45+00:00
    Safe mode still fails the same as previous build and the same behavior as Dev and Beta.
    The problem is caused by the same experimental features enabled in these insider builds. 🤐🤷‍♂️
    https://aka.ms/AAm0wy5
    Same for me. After the Unknown Hard drive error window I can bring up Task manager and Restart from that. Reliability monitor shows multiple instances of Explorer crashing.
    2023-08-16T07:41:51+00:00
    Today when arriving at the desktop after first startup I had this error window. Reliability monitor shows several instances of the faulting application as well as an entry for Failing application WerFault.exe.
  5. CrazyKats 19,680 Reputation points Volunteer Moderator
    2023-08-16T12:50:00+00:00
    Related to the CxUIEI error I found thion the web:
    From File.NET
    Also from File.NET
