Build 25926 out to Canary Channel
CrazyKats 19,680 Reputation points Volunteer Moderator
2023-08-09T17:00:36+00:00
Live in W.U.
  1. CrazyKats 19,680 Reputation points Volunteer Moderator
    2023-08-12T22:24:54+00:00
    Oh my, I got rid of the Windows Intelligence Update.
    After trying many other things (that didn't work) I
    used the new repair install option in Recovery.
    After it was finished and Windows Update checked
    for updates it now shows as completed.
    2023-08-13T05:46:18+00:00
    Yep, that worked for me too.
    It also worked to get rid of that pesky .net update that keeps calling for a restart.
    2023-08-13T08:20:47+00:00
    I got rid of mine, using the suggestion to pause updates and searching for updates again. This worked on both my canary installs
    2023-08-13T09:08:23+00:00
    i have this error 0xc1900101 (it doesn't say the type of error) from the latest builds and i cant update. After reboot it gets stuck on windows logo and does nothing. I have to turn it off and after turning it back on it rollsback.
    All the drivers are up to date. Antivirus is off. All usb are disconnected during restart.
  5. Johnny55 5,155 Reputation points Volunteer Moderator
    2023-08-13T15:13:25+00:00
    Good morning CK,
    Confirm that this worked for my virtual machine. It ran for about 15 seconds and was done. There was no complete repair install, but this worked somehow 👌
    Regards,
    Edit: Still have ongoing concern with Xbox Identity Provider. This is with the upgrade as well as the total clean install of this build.
