These new flyouts will appear when you press the volume or brightness keys on your laptop
This is the part I missed. It's only on Laptops.
If I press the Volume FN key it brings up the
new volume slider in the image.
Installed on both my laptops so far so good! No issues. :)
Maybe it depends on the model of your laptop, not on my MSI laptop.
The FN key for the volume or brightness pop up its own image for the volume and brightness adjustment, that was the same with previous build, nothing changed with this one in my case, I don't see any different flyout.
Finished installing, came up with black wallpaper. This is not what had it set to prior to this build.
@J W Stuart,
I get that black wallpaper every time I upgrade from Windows 10 To Windows 11 Dev.
But when I update from a previous dev Build, it preserves the previous background settings.
