Not FG, but as far as I know it's normal behavior.
If left aligned no Weather/Temp.
@CrazyKat, @Sibro.0,
That is the bug reported on the Blog, they did not fix it yet.
When taskbar is left aligned it chops off the information on the right of the widget icon.
What's normal behavior when the Taskbar is centered?
The first screenshot above?
