Checked (my) Notepad and could not/cannot repro "this problem".
You can reproduce it if you change the accent colors, it affects differently the Dark mode and the Light mode.
Both are easy to reproduce just by changing the accent color selected.
I see, ok. With whatever accent I have, including Dark it (corner buttons) seems quite fine.
Cheers,
Drew seems quite fine.
Sure, 50% chance to be lucky! 🤣
Look again:
You have total used space is 85,5 GB (for pictures, App, Temp and other) and free space is 131 GB
Temporary files take only 7.38 GB of this used 85,5 GB disk space.
