RS-Prerelease Build 22533.1001 is out to Dev Channel + ISO
2022-01-12T18:00:15+00:00
Live in W.U.
Windows Insider program | Windows Insider preview | Windows AI
    2022-01-15T07:30:10+00:00
    I have tried both Centred AND Left & do not have the Widget weather icon; even with the default taskbar, which I don't use, normally.
    Now of interest... on page 5 I showed the Time & Date window was ok & normal... I just checked it again and lo & behold; it no longer is... I will report this to FH.
    https://aka.ms/AAfgzwi
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/085eb40d-061b-45b5-914d-9f5dc301a57b?platform=QnA
    The same happened to me, it is the update of the English (United States) Local Experience Pack that causes the problem, the same happens for other languages all over the world.
    You can check the Version level that was updated on your machine.
    On mine I can eliminate the bug if I remove the English (United States) Local Experience Pack which in my case is 22535.1.1.0, or if I put back the previous Version 22534.1.1.0.
    Not sure if you have a different pack for Canada, just check what was updated from the MS Store.
    2022-01-15T08:15:24+00:00
    Another screw-up caused by the Language Local Experience Pack :
    This is the Color menu instead of showing Light, Dark, Custom it shows Span, Fit, Fill 🤣
    If I remove the English (United States) Local Experience Pack using Power Shell command below, I get back the normal correct menu.
    Get-AppxPackage Microsoft.LanguageExperiencePacken-US -AllUsers | Remove-AppxPackage
    2022-01-15T09:09:55+00:00
    I have that, also. For some reason what I have is English (United Kingdom) Local Experience Pack. Have had it for a VERY long time. Never really knew what initiated it. There is no way to remove or uninstall it; only Manage... which leads toImage If it is the cause of these anomalies, it has started with 533.
    If I knew the command line for this specific pack, I would sure use it. Tired what you showed, changing US to UK, but to no avail.
    Cheers,
    Drew
    ![Image](https://learn-attachment.microsoft.com/api/attachments/146f1136-cb60-4647-ad41-1c72453b2a18?platform=QnA
    2022-01-15T10:40:05+00:00
    Sorry to butt in, but I believe you can change, or delete it via Control Panel. Same with the keyboard
    2022-01-15T16:37:37+00:00
    To find Apps full names use
    Get-AppxPackage -AllUsers | Select Name, PackageFullName
    Using asterisks makes it easier.
    Get-AppxPackage *LanguageExperiencePack* | Remove-AppxPackage
    Then, you can install the correct package but as already explained by fg, to avoid the bug you have to install the previous version.
