What the 😲😕❗❗❓❓
Thanks for your comment. I couldn't explain my issue better. 😂😂😂
What the 😲😕❗❗❓❓
If you are curious, see here what it is for:
Thanks but like I suspected, it is nothing special plus I don't need it.
Hi.
I got something funnier.
When I click "Time and Language" and then click "Add language", a new window opens and I have very strange wording.
The new window has a Heading titled "Punishment Science" instead of "Choose a language". The O.K. button reads "Mechanic" and the Cancel button reads Highway Transport Technology.
Looks like they screwed up all the Local Experience Packs for the different languages.
Hi IanRG,
All I have to do here to solve the problem is by removing the latest version 22535.1.1.0 and reinstall older version 22534.1.1.0. and then stop the update from the MS Store.
I use the following PowerShell commands; you can probably change these to match the Pack and version for your Zone Language, I don't know which one you use, your snapshot showed Camberra,Melboune,Sydney.
Mine is for en-US and the problem goes away if I reinstall the older version 22534.1.1.0.
Get-AppxPackage Microsoft.LanguageExperiencePacken-US -AllUsers | Remove-AppxPackage
Add-AppxPackage -register "C:\Program Files\WindowsApps\Microsoft.LanguageExperiencePacken-US_22534.1.1.0_neutral__8wekyb3d8bbwe\appxmanifest.xml" -DisableDevelopmentMode
I appreciate the work around, but the silly mistake by Microsoft does not make the computer unusable. It is up to Microsoft to fix the problem.
