Build 27686 is out to Canary Channel Updated Blog
2024-08-15T17:00:42+00:00
Live in W.U.
    2024-08-16T21:47:39+00:00
    I am not on the Canary builds but was wondering if anyone knew the motivation for what shows below. Is it just they want to be able to use FAT32 for the larger install files without special procedures?
    [Storage]
    • When formatting disks from the command line using the format command, we’ve increased the FAT32 size limit from 32GB to 2TB.
    The file size limit for FAT32 is still the same, 4GiB.
    The only thing they changed is allowing formatting of FAT32 for drives bigger than 32GB.
    There was no reason for that 32GB drive size limit on FAT32, it was a completely arbitrary limit set by Windows. 🤐🤷‍♂️
    2024-08-16T22:34:35+00:00
    Back in days of yore when resources were limited, the 32GB limit allowed using half-words (i.e. 16bits) instead of full words (i.e. 32 bits). Today that seems extremely silly, but back when MS set the limit (maybe 25 years ago?) we had to limit things because RAM and other resources were extremely limited compared to what we have today. I'd say MS was probably very late making this change, but better late than never I guess.
    2024-08-17T03:08:54+00:00
    As per blog, I guess this is just the 1st step for fully supporting this change.
    [Storage]
    I could format this drive with FAT32 using the format command in DISKPART, but the context menu for formatting a drive still does not show the FAT32 option for a drive bigger than 32GB. 😂
    The FAT32 option on this context menu is still only available up to 32GB. 😎🤷‍♂️
  4. Drew - 810 Reputation points
    2024-08-17T07:46:19+00:00
    Took a while 🥱
    Well, it's live, now (for me) & seemingly running alright, but poking around in it (by me) will have to wait until tomorrow. I'm it sure it will be fascinating 😏
    We know this, but others may not realise... 27686 is no longer "24H2" & has moved away from & beyond that.
    Edition Windows 11 Pro Insider Preview
    Version Dev
    Installed on ‎2024-‎08-‎16
    Evaluation expires on ‎2024-‎09-‎15 4:37 PM
    OS build 27686.1000
    Experience Windows Feature Experience Pack 1000.27686.1000.0
    Good night 💤
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/8222db28-2d64-411f-8b8b-faca133501f6?platform=QnA
  5. Johnny55 5,155 Reputation points Volunteer Moderator
    2024-08-17T18:27:48+00:00
    Hi FG,
    Confirm on total clean install. Insider page stuck on Beta with other options not available:
    Defrag & Optimize Drives missing SXSHARED_UCRT.dll. Ran sfc and Dism restore health to no avail.
    Regards,
    PowerShell Commands for those interested, Defrag or Trim in Canary:
    Optimize-Volume -DriveLetter C -Defrag -Verbose
    Optimize-Volume -DriveLetter C -ReTrim -Verbose
    FBH Report Stuck on Beta via Clean Install
    Regards,
