Build 22000.282 for Beta and Release Channels
CrazyKats 19,420 Reputation points Volunteer Moderator
2021-10-15T17:03:50+00:00
Windows Insider program | Windows Insider preview | Windows AI
    2021-10-16T04:39:57+00:00
    I did a reset of the Store app and it starting working again.
    The reset seems to work now on all the ones that were failing earlier, Windows 10 and Windows 11.
    It sure did not work earlier, but now it did.
    2021-10-16T07:42:24+00:00
    Hi.
    I want to install this CU on my non-compliant PC, which cannot be on Beta or RP channel.
    I downloaded the files (KB5006746) from a reputable source but there is a file with an extension (.psf) unknown to me. Does somebody know how to install it using dism command-line tool ?
    2021-10-16T09:03:27+00:00
    Hi.
    Hi Suat,
    I already have one compliant box at 22000.282 that was updated with W.U.
    For the non compliant I'll try with a 22000.282 ISO and update from 22000.258.
    We'll see if I can get that to work. 😉
    I don't know how the .psf files are applied, I ran into those before and didn't figure out how they get applied.
    Maybe Johnny_55 knows how those work.
    Perhaps it may be easier to get the ISO file for 22000.282 and update with that ?
    I'm downloading and building it right now.
    I'm going to try that later on my non compliant Laptop which is currently at 22000.258 and was previously upgraded with ISO from 19043.1288.
    41fdbca3d0868b158a332a744f5ede77d83f2e2e *Windows10.0-KB5004567-x64-baseless_41fdbca3.cab
    87afeecd1e0a587f16390eac4ee277269ef80e39 *Windows10.0-KB5004567-x64-baseless_87afeecd.psf
    611502dae49fd21cc5f5c1b4c998d9e75cfe099a *Windows10.0-KB5004567-x64_611502da.cab
    391629547c8fe9a15107c12ab92f7c14a80eec72 *Windows10.0-KB5005662-x64-baseless_39162954.psf
    5d89e54a935b98ebadb4708f0e6c9e8e04c8d34c *Windows10.0-KB5005662-x64-baseless_5d89e54a.cab
    fd810df791acdd5e5e4c593795b3b211287ffc2c *Windows10.0-KB5005662-x64_fd810df7.cab
    27aa191291bf64f5c3de446aa874b4ee54cb9acb *Windows10.0-KB5006587-x64_27aa1912.cab
    55bb1eba70c6b0dcd2800d41fd4bdf07f5efd719 *Windows10.0-KB5006746-x64_55bb1eba.cab
    7cd9b866dc3492c0d272042c3d72298ebdfc1b83 *Windows10.0-KB5006746-x64_7cd9b866.psf
    2021-10-16T09:24:14+00:00
    Hi fg,
    I find it easier, faster and safer to downland the ISO without the updates and let WU do the rest.
    Remember, it will update only once to the latest build plus the .NET updates.
    2021-10-16T09:33:12+00:00
    Hi fg,
    W.U. will not update to 22000.282 the non compliant laptop because it cannot enroll in Beta.
    The ISO is doing the Update right now from 22000.258 to 22000.282 without insider channel.
    This is a legacy BIOS machine 😉
    Almost done, it is restarting right now...working on updates 31%...68%...74%....88%...
