Build 22000.282 for Beta and Release Channels
CrazyKats 19,420 Reputation points Volunteer Moderator
2021-10-15T17:03:50+00:00
Windows Insider program | Windows Insider preview | Windows AI
    2021-10-20T12:26:37+00:00
  2. Deleted
  3. Deleted
    2021-10-21T01:39:59+00:00
    Hi fg,
    Remember last night, the VM ended up like this, perfectly happy on latest Beta correct?
    Look at it now, what the heck happened? 🤷‍♂️
    2021-10-21T02:00:28+00:00
    Hi fg,
    Hi Sibro,
    If you are still on Beta, run PC Health Check and see what is complaining about.
    If this is VM, perhaps it is still checking the processor type and it could be considered a yellow zone Virtual Machine ? 😉
    It would not let you on Beta if it was a red zone case. MS keeps tightening and changing the rules ...
    Edit:
    If this is the same VM, did they just kick the Virtual Machine out of insider ?
