Build 22000.282 for Beta and Release Channels
CrazyKats 19,420 Reputation points Volunteer Moderator
2021-10-15T17:03:50+00:00
Windows Insider program | Windows Insider preview | Windows AI
    2021-10-16T12:18:31+00:00
    I've got the Diagnostics & feedback settings the same as yours, Sibro, but WU still says I'm up to date at 22000.258. ???
    I tried to update my non-compliant PC, which is obviously neither on beta nor on RP, from build 22000.278 to build 22000.282 using an ISO compiled from a known, reputable source. As expected, I couldn't do it. The Windows installer gave me a frowned look: "This PC can't run Windows 11."
    Therefore, I went back one step after I got scolded by Windows installer while it was still running and deleted some files that were giving me that frowned look.
    Now I have Windows 11 build 22000.282.
    As you can see, I am trying very hard to help Windows take a better shape and look.
    2021-10-16T13:01:11+00:00
    FG , so am I on the public build (kb5005537) ?
    I found the answer : https://support.microsoft.com/en-us/topic/windows-11-update-history-a19cd327-b57f-44b9-84e0-26ced7109ba9
    2021-10-16T15:51:38+00:00
    Same Here CK and FG, broken Store
    Thanks for confirming.
    I was in the middle of an update, now I have to wait, but no idea when it will be fixed !🤔
    It's working again perfect this morning. Perhaps it was a server problem 🤔
    I'm not sure what it was 🤷‍♂️
    2021-10-16T16:57:55+00:00
    I had to issue a Reset of the MS Store app to get it to work again on the machines that were failing.
    Clearly MS fixed the problem on their side later yesterday. It was failing on every machine for me.
    2021-10-16T17:10:22+00:00
    Hi Suat,
    Looks like you don't know know about appraiserres.dll trick in the sources folder ?
    I updated my non compliant Legacy Bios Laptop from 22000.258 using the downloaded .282 ISO, (offline update).
    The only problem I see is that the I don't get the latest Apps from MS Store because I'm not in the Insider Beta on that machine.
    It will probably update when MS releases .282 to the public. 😉
