Error 0x80888002 on build 22509
2021-12-02T03:25:28+00:00
Split from this thread.
Windows 11 Insider Preview 22509.1000 (rs_prerelease)
Download error - 0x80888002
    2021-12-02T11:53:40+00:00
    I cleaned windows update cache, but same issue when downloading again, it stops at 8% and can't complete update. Don't know if I can try something else, or it is a matter of waiting for a fix from MS.
    2021-12-02T13:24:07+00:00
    Had the same on my Sony Vaio (yellow compliant). Finished up installing via ISO from another update
    2021-12-02T17:31:05+00:00
    Hello, I had that error, I then copied the file appraiser.dll from 22504 c:\windows\system32 into the $windows.~BT\sources and the update proceeded. Then I made a backup of that file into another disk just in case. Suggestion: when it get to the 8% step the sources folder get "full", keep an eye on it to see if the 22504 appraiser.dll is not overwritten. (Done in a system "red flag"). Worked, now on 22509. Sorry for my english.
    2021-12-02T17:56:23+00:00
    Upvote Feedback: https://aka.ms/AAf1czd
    Hi Sumit,
    Upvoted.
    2021-12-02T18:57:33+00:00
    You should just wait for a MS fix.
