Error 0x80888002 on build 22509
2021-12-02T03:25:28+00:00
Split from this thread.
Windows 11 Insider Preview 22509.1000 (rs_prerelease)
Download error - 0x80888002
    2021-12-02T04:09:44+00:00
    Hi Sibro,
    I found a way around the latest nail and error 0x80888002, but not a solution that I like...
    MS will probably add a new nail to block it again.
    New game, but it is just a waste of time. 😜
    Kudos!
    I agree, I stopped playing the game after the RPi4B was degraded to RP
    edit: are you 100% sure this is a "nail"?
    2021-12-02T04:15:55+00:00
    Looks that way, I got it updated, but not worth the effort.
  3. Pauli O 16,380 Reputation points Volunteer Moderator
    2021-12-02T04:19:29+00:00
    >"I got the same error on 2 different boxes that do not meet the requirements"
    Which part of those boxes isn't W11 compatible?
    I updated two devices which have secure boot and TPM 2.0 enabled but CPU isn't list of supported processor (gen 6 and older Xeon).
    Both download and completed update via W.U. without any issues.
    2021-12-02T04:22:22+00:00
    @Pauli O,
    Yours are yellow zone, mine are red zone, big difference!
    I have 2 machines that are still Legacy BIOS.
    Both ended up with Error 0x80888002 on build 22509 download.
    I managed to update them, but I have to pull too many nails to get those up to 22509.
  5. Sumit 44,306 Reputation points Volunteer Moderator
    2021-12-02T04:26:27+00:00
    Just tried downloading, hitting the same error. Fully compatible machine in "green" zone.
    Filing FB now.
    Edit:
    The log files indicate a failure during compat scan too...
    2021-12-02 08:45:21, Error CONX Windows::Compat::Appraiser::Utilities::ExtractResourceToFile (675): Could not LoadLibrary to resource: [2].[gle=0x80070002]
    2021-12-02 08:45:21, Error CONX Windows::Compat::Appraiser::SetupAppraiser::InitializeData (1640): Failed to extract data file resource: [0x80888002].[gle=0x80888002]
    2021-12-02 08:45:21, Error CONX Windows::Compat::Appraiser::SetupAppraiser::InitializeSetupRunInfoOptionsDataAndGated (535): Error initializing data: [0x80888002].[gle=0x80888002]
    2021-12-02 08:45:21, Error CONX Windows::Compat::Appraiser::SetupAppraiser::ScanInternal (258): Initialization failed: [0x80888002].[gle=0x80888002]
    2021-12-02 08:45:21, Info CONX Appraiser: TRACE,SdbReleaseDatabase,84,Enter.
