Hi fg,
I just removed that from my signature last week 😂
This is a Dell Inspiron 5590/Core i5 10th gen/12GB of RAM.
On the machines you use the workaround, are they on green zone or yellow zone?
Hi Sumit,
I think I mentioned earlier, in my case I don't have any problems with fully compliant boxes, I have a Lenovo Yoga 920 laptop with I7 8550U, Dell Desktop 8930 with I9-9900K, Dell Desktop 8940 with I7 11700, all 3 complete the updates fine without any hack.
I see the Error 0x80888002 only on red zone boxes, my only yellow zone box is my production machine, and I leave that alone, I don't use it for testing.
Your box apparently is fully compliant, so the problem has to be a screwup on the MS check for the requirements.
I got 2 machines in the red zone updated to 22526, but clearly those needed some known tricks to get over the blocks and the 0x80888002 error.
MSI GT70-0NC Laptop and Dell XPS 8300 (Legacy Bios) are both up and running with 22526.
I'm sure MS will come up with some other new block on next builds. 🤷♂️
I have a green zone box and I first ran into the error with 22509. I was still getting the error when 22518 came out and was initially unsuccessful at installing that build as well using the appraiser fix plus several others I tried.
It wasn't until I ran the Skip_TPM_Check_on_Dynamic_Update script from GitHub before doing the update that I was successful.
I've since had no problems with 22523 or 22526.
I never did get 22509 installed.
