Error 0x80888002 on build 22509
2021-12-02T03:25:28+00:00
Split from this thread.
Windows 11 Insider Preview 22509.1000 (rs_prerelease)
Download error - 0x80888002
  1. Deleted
  2. Deleted
    2021-12-14T05:10:09+00:00
    Yes, there is no media creation tool but, you can download the iso of this build at this site:
    Select edition for Cumulative Update for Windows 11 Insider Preview (10.0.22518.1012) amd64, English
    As long as you are aware that this is a third party site and not supported by Microsoft. The official Microsoft ISO is still 22499. 😉
    2021-12-14T05:59:31+00:00
    Did your PC Meet The Requirments?INSTALL 22509.1011!
    Yes. i7-10700, MSI Z490-A PRO motherboard, PTT enabled in BIOS, etc. I had the same issue with 22509.1011 and 22518.1000.
    That's what made it so perplexing. All previous builds and updates installed without issue. In case you missed it, I mentioned elsewhere that I was finally able to get past the error using a script from GitHub that bypasses the TPM check on dynamic updates.
    Updates since then have been working fine. As of this posting, I'm on build 22518.1012.
    2021-12-14T10:09:23+00:00
    It's Showing Windows Server Setup on Top
