Can we use First Windows 11 Adk 22518?
Error 0x80888002 on build 22509
Split from this thread.
Windows 11 Insider Preview 22509.1000 (rs_prerelease)
Download error - 0x80888002
2021-12-09T14:55:10+00:00 -
2021-12-09T14:56:58+00:00 Where are the download links?
2021-12-09T15:04:31+00:00 New error, now installing update 22518.1000 (rs_prerelease), my computer completed download, and now I get this error installing...
MoUpdateOrchestrator Success Content Install Installation Started: Windows has started installing the following update: Windows 11 Insider Preview 22518.1000 (rs_prerelease) eYzqqdd0kU6/9hEQ.20.2.1.0
MoUpdateOrchestrator FailureContent Install Installation Failure: Windows failed to install the following update with error 0xc1900130: Windows 11 Insider Preview 22518.1000 (rs_prerelease). eYzqqdd0kU6/9hEQ.20.2.3.0
Anyone with same error?
2021-12-09T15:19:10+00:00 This is the link I used for installing Windows 11 IP's on a really old HP Laptop. I think if the Registry hack works on an 8 years old machine, it'll work on just about any PC.
How to install Windows 11 on any non compatible Windows 10 PC (thegeekpage.com)
Good luck!
2021-12-09T15:20:53+00:00 The link is right there in the text.
github (dot) com /AveYo/MediaCreationTool.bat
just remove all the spaces and replace the "(dot)" with a real dot.
