Error 0x80888002 on build 22509
2021-12-02T03:25:28+00:00
Split from this thread.
Windows 11 Insider Preview 22509.1000 (rs_prerelease)
Download error - 0x80888002
    2021-12-03T19:44:41+00:00
    My system meets all requirements for Windows 11 as verified by the latest version of PC Health Check, but it will not install IP 22509. Install goes fine until about the 8% mark where (based on other comments I read) the 22509 appraisser.dll does a scan of the specs to verify system compatibility with W11 and then errors out. Get a grip, MS - my Ryzen 5 system shouldn't pass one tester and fail another. Needs some help here! :-) Oh BTW, I am currently running IP 22504.
    2021-12-03T20:17:32+00:00
    I think that is the case. Here is another new one that showed up today after an upgrade.
    It cleared after I hit retry all.
    Hi fg,
    Fun fact: had no error clean installing 22509 or updating to .1011 on the RPi4B 😁
    2021-12-03T20:31:21+00:00
    Hi fg,
    Hi Sibro,
    I'm never surprised by MS inconsistency.
    There are so many different machine configurations, they have a hard time covering all the cases correctly and end up creating new bugs. 😆
    Edit:
    Did not have any issue with clean install on unsupported, just the usual known tricks.
    No problems updating to 22509.1011 either.
    2021-12-03T20:32:02+00:00
    You can either wait for a fix from MS or try the workaround suggested earlier in this thread by JuarezFioravanti Filho.
    Apparently, MS screwed up the appraiser.dll in build 22509. 🤔
    2021-12-04T16:27:13+00:00
    my microsoft insider error
